28.4 Vertex Attributes Bug
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
AlexeyAdamitsky
It doesn't seem to be working. Render doesn't show the values for the vertex color.
linograndiotoy
Works here:
opstyix
Hey Alexey, I noticed you're using the incorrect node.
The Grayscale Vertex Attribute node shown in your screenshot is linked to Vertex Groups, which explains why it's not showing in rendered view. While the Color Vertex Attribute node is used for Color Attributes.
AlexeyAdamitsky
opstyix wrote:Hey Alexey, I noticed you're using the incorrect node.
Thanks for the tip. You're right if I use Color Vertex Attribute it works as expected.
When and how do we use Grayscale Vertex Attribute in Blender then?
linograndiotoy
Grayscale Vertex Attribute is meant to be used with Vertex Groups.
Return to “Bug Reports”
