Triplanar mapping without UV set
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Andreas_Resch
In the latest addon (28.3), the Triplar mapping doesn't work when the object has no UV set assigned (which it should not require). As soon as I assign a dummy UV set, it works. Using a projection like Sperical however works, even without an assigned UV set.
Furthermore the UV mapping itself affects the Triplanar mapping. If I change the UV mapping, the Triplanar mapping changes as well. That's not how it's supposed to work, right?
linograndiotoy
It looks like the Triplanar Projection node is not correctly "translated" into the Octane nodegraph at the moment. We'll fix this.
Thanks for reporting this, Andreas!
Andreas_Resch
No worries. Thanks for forwarding it to the devs.
Return to “Bug Reports”
