In the latest addon (28.3), the Triplar mapping doesn't work when the object has no UV set assigned (which it should not require). As soon as I assign a dummy UV set, it works. Using a projection like Sperical however works, even without an assigned UV set.
Furthermore the UV mapping itself affects the Triplanar mapping. If I change the UV mapping, the Triplanar mapping changes as well. That's not how it's supposed to work, right?
Triplanar mapping without UV set
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
It looks like the Triplanar Projection node is not correctly "translated" into the Octane nodegraph at the moment. We'll fix this.
Thanks for reporting this, Andreas!
- Andreas_Resch
No worries. Thanks for forwarding it to the devs.
