Tried to access attribute via invalid ID A_COMPATIBILITY_VER
Vivimagic
Cinema 4D 2023.2.2 - Octane Render 2022.1.1r6
I have opened an old scene to grab some materials for a new scene file. When I send the scene to the IPR for the first time the IPR gives me an error and error the log comes up.
Started logging on 17.08.23 13:59:37
OctaneRender Studio+ 2022.1.1 (12000102)
VRAM used/free/max:0Kb/23.988Gb/23.988Gb  Out-of-core used:0Kb  RAM used:31.437Gb total:94.632Gb  OpenGL free/total:0/0
C:\Program Files\Maxon Cinema 4D 2023\plugins\c4doctane/res/32x/clear.png
--------------------------- EXPORT LOG ---------------------------
Tried to access attribute via invalid ID A_COMPATIBILITY_VERSION (438)
Export materials time= 2281.901 ms
Collect objects time= 12.171 ms
Mesh creation time = 1966.625 ms.
Failed to build OCIO output transform: No OCIO config loaded
Api update time: 6.093 ms.
 MB:0/0  ST/MOV:0/723  Nodes:2101  Tris:6.514m  DispTris:0  Hairs:0  Meshes:694
 Textures Grey8/16:0/0  Rgb32/64:5/0
Don't know what exactly it referencing but it stopping the render to happen as it just shows a black box in the IPR.
The issue is that if I send this to the farm and if each node has trouble starting up with the errors I won't be able to render on the farm.
Any idea what to do to fix the the error?
Can't send file due to NDA.
It's not an error would cause any trouble for you. It's an warning we trying to access unavailable attribute in a node.
