I have opened an old scene to grab some materials for a new scene file. When I send the scene to the IPR for the first time the IPR gives me an error and error the log comes up.
Started logging on 17.08.23 13:59:37
OctaneRender Studio+ 2022.1.1 (12000102)
VRAM used/free/max:0Kb/23.988Gb/23.988Gb Out-of-core used:0Kb RAM used:31.437Gb total:94.632Gb OpenGL free/total:0/0
C:\Program Files\Maxon Cinema 4D 2023\plugins\c4doctane/res/32x/clear.png
Tried to access attribute via invalid ID A_COMPATIBILITY_VERSION (438)
Export materials time= 2281.901 ms
Collect objects time= 12.171 ms
Mesh creation time = 1966.625 ms.
Failed to build OCIO output transform: No OCIO config loaded
Api update time: 6.093 ms.
MB:0/0 ST/MOV:0/723 Nodes:2101 Tris:6.514m DispTris:0 Hairs:0 Meshes:694
Textures Grey8/16:0/0 Rgb32/64:5/0
The issue is that if I send this to the farm and if each node has trouble starting up with the errors I won't be able to render on the farm.
Any idea what to do to fix the the error?
Can't send file due to NDA.
