Radial noise
AdrienG
Hi everybody,
Is this possible to achieve this kind of noise ?
I have unpredictable result with a spherical proj.
Cheers
AdrienG
cant get a real solid setup :
BK
AdrienG wrote:cant get a real solid setup :
Hi AdrienG,
Thank you for the reference.
Is it something like the sample you are after?
Cheers
Adrien.zip
(9.61 KiB) Downloaded 533 times
Kind Regards
bk3d
AdrienG
Very cool it works thank you !
Despite the seam it s perfect. I guess with a mask and mix texture we could deal with that.
Different and same subject, i m trying to get the perfect radial anisotropy and found out the best tutorial about it :
https://lesterbanks.com/2022/08/working ... cinema-4d/
Gradient generator with gamma set to 1, invert ON. Projection UV. Transform set to -90 degres.
Return to “Autodesk Maya”
