Denoiser ON makes PC slow
coilbook
Why does denoiser kill PC performance? CPU always calculating something, display card is not even in use, and de-nosier is only available on completion. Rendering increases by 200% - 300%
Even after rendering is done in octane viewport if de-nosier is on PC will be always slow
Rik
Same here...
frankmci
This has been a known problem for some people. Do some searches of the forums for details.
whersmy
do you mean rendering speeds increases by 200-300% if you only denoise on completion?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
paride4331
whersmy wrote:do you mean rendering speeds increases by 200-300% if you only denoise on completion?
This makes sense. If you perform denoising only at the end of the rendering process instead of at regular intervals during rendering, the rendering time is significantly reduced.
Regards
Paride
coilbook
Regards
Paride
Denoiser is set at the completion and the actual denoising takes 2-3 seconds but overall rendering goes from 1 min to 2 min per frame. It's like cards render slower. Can the devs look into it? Thanks
Return to “Autodesk 3Ds Max”
