ORBX File only contains one frame?
Discussion forum for ORBX.js
iandoug56
Hey guys, having this really weird issue where my ORBX file only contains one frame of my 250 frame animation. The output range is correct, and I know that for a fact because I watched it go through each frame on the render viewer. When I open it in standalone or upload it to the rndr network, it only shows up as a singular frame which makes 0 sense.
Here is a link to the C4D file and the ORBX file: https://drive.google.com/drive/folders/ ... sp=sharing
I've done this multiple times with this file, and it seems like only with the most recent version does it have this glitch. Any help would be appreciated. Thanks!
the Alembic asset is missing from google drive folder, so the c4d scene cannot be checked.
Try to import the Alembic file in Standalone, in the exported 1 frame .orbx scene, to replace the static geometry object.
Note that you need to click on the wrench icon in Node Inspector, to change the Alembic scale to centimeters.
ciao,
Beppe
Return to “ORBX.js”
