Hi
Looking forward to using the newest release soon. Right now I can't access the vertex colors on a mesh using the octane attribute nodes (Col, Col.001).
Wiring it directly using the octane Node view doesn't work either. Using Cycles, it works, the vertex colors show.
in the previous 2022.1_27.5_beta (3.3) it worked too.
Thanks for any hints!
Trouble accessing vertex colors 2022.1_27.1 (3.4.1)
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
That's been fixed in the upcoming version.
in case someone needs it here's the code used to convert the vertex color storage type:
for o in bpy.context.scene.objects:
bpy.context.view_layer.objects.active = o
try:
o.data.vertex_colors.active = o.data.vertex_colors["Col"]
bpy.ops.geometry.color_attribute_convert(domain='POINT', data_type='BYTE_COLOR')
o.data.vertex_colors.active = o.data.vertex_colors["Col.001"]
except:
print(f"trouble converting vertex colors for {o.name}")Core i7 980 x GTX 980
