Color RGB to float
Houdini Integrated Plugin
Futureboy
Hi!
I was looking for getting a float output from a RGB. On the tool nodes there is only "float to RGB" but not "RGB to Float".
Node like "Tool_ColorCorrection" require a float input to drive some parameters. I tried to use an RGB as input but it's not considered by the Tool_ColorCorrection
I attached a screen grab of the network to better explain.
Any suggestion?
G.
juanjgon
The problem is that this input pin is not texturable. You can't link texture nodes (nodes that have a texture output) to this input. It only supports const floats.
Futureboy
Thanks Juanjo for the clarification.
G
ArtyomPapikyan
is there any way to convert color to float? Sometimes I really need to manipulate float data. :?: :?: :?:
dom_otoy
ArtyomPapikyan wrote: Tue May 20, 2025 12:29 pm is there any way to convert color to float? Sometimes I really need to manipulate float data. :?: :?: :?:
Are you wanting to plug a texture into a float input? If so that's not possible.
Now if you're wanting to split one channel out of color texture you can do the tool channel pick node.
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
Return to “Houdini”
