increasing render time
- prodigiosovolcan
What do you have? Motionblur, particles?
- prodigiosovolcan
None of them, just some simple animationsaoktar wrote:What do you have? Motionblur, particles?
You need to make tests it more before asking here. Check is it a slowness on rendering on specific frame for example. Or same if you start on different frames, more info is more ideas.
I see your other report here: viewtopic.php?f=30&t=81322
Your problem maybe related to out of VRAM and need to use OOC and slowing down of render because it. Try to remove some textures/etc... for testing
- jayroth2020
To add to what Ahmet wrote, make sure that your textures are set up properly in the Image Texture node; only the Diffuse texture should be set to Normal; set other textures for bump, displacement, specular and so on to Float. If you are using Normal Maps, use Non_Color Data for those.
