cinema 2023 octane live view not updating
spigolo
Hello,
Im new to Cinema4d but I used Octane in lightwave in the past and in Modo recently.
I don't understand why in cinema 4d I have to always press the octane button in the live view to get an update of my view
when I change parameters like colors or hdri rotation...IN Modo everytime you change something the view updates...
but here is so annoying.
Am I missing something?(I already activated the icons on the right side refering to the camere, geometry updates etc.)
3dsign studio
Advanced visual communication
http://www.3dsign.it
SSmolak
Check if you have these nice options turned on :
It's not expected case and not normal of that. Maybe you changed some settings. Better to reset your octane preferences. Delete oct.dat in prefs directory.
spigolo
I will try that...
anyhow the most annoyng issue is that when I try to rotate an hdri image set as environment I can't see it in realtime and
this slow down a lot the setup of a scene.
I already have all the options activated.
3dsign studio
spigolo
I went in the prefs folder but I can't find the Oct.dat file...
3dsign studio
spigolo
Ok,
I have realized that you have to move the hdri environment as an object...so working with coordinates..
My fault!
3dsign studio
