Denoiser Issues with Standard Surface
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
AlexeyAdamitsky
Ok, I don't know if it's expected behavior or a bug. But it's definitely not the result a user would expect to get.
I used simple Diamond material using Standard Surface. Here are the settings:
When Octane Denoiser is applied, the result is getting very muddy for the gems.
As soon as I change the Transmission Weight up to 100% Denoiser works as expected.
I assume it might be a bug.
john_otoy
Thanks for the report. I can reproduce this in standalone.
kabakZ
Hi Alexey, have you tried reducing the base weight to 0 or set it to Black? Also, did you get different result without a denoiser?
Return to “Bug Reports”
