Light passes and instanced objects
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
apatrick
I've been trying to disable a light pass on a set of instanced objects. I may have misunderstood how this is achieved, but disabling the pass on the octane parameters on a geo node doesn't appear to work when the node contains either packed or instanced geometry.
I attach an example which shows the problem.
lightgroups.zip
(97.45 KiB) Downloaded 192 times
juanjgon
Yes, this seems to be a limitation of the packed instancing code. As a workaround, you can use the conventional instancing if you configure the light passes in the master objects. I'll take a look at it to check if this limitation can be fixed.
Return to “Bug Reports”
