Displacement Border Mode Limitation
Mr_Uzu
So I hitted a wall with displacement repeating when specified (in greyscale image node)it shouldn't.
I've seen in c4d help that this limitation is now gone (for them) but modo still have it?
Any info if this will be adressed? Or maybe some workaround?
Mat
funk
There are 2 types of displacement nodes in Octane.
The issue you mentioned is a limitation (in the Octane core) of the "Texture displacement" node.
NOTE: The plugin uses this node by default when using the shader tree.
https://docs.otoy.com/ModoH/ModoPluginM ... cement.htm
You'll need to use "vertex displacement" if you need control over border modes.
Return to “Foundry Modo”
