alpha in AOV
g5cedric
Hello, I would like to have the reflection pass in the AOV without alpha, but keeping the Beauty with alpha, possible?
if you have any ideas…
thank you very much
here are some screenshots to show you:
Cedric Uebersax, Photographer at France | http://www.cedric-u.com |
- Win11 ProArt X670E Creator 1x RTX 4090
- Win10 1909-Asus X-99 2x RTX 3090
- MacPro 7,1 Pro Vega II Duo
C4D R2023 / 2021.1.6
my suggestion is to render the beauty and reflection AOVs with Affect Alpha option disabled, then use the C4D Takes system to enable the Affect Alpha option, and reduce the max sampling via Overwrite kernel Setting tab, to only obtain the correct alpha you need.
ciao,
Beppe
