16 bit EXR "save all passes" option
Dingbat
seems that 'save all passes' only has the 32 bit exr option
can we have a 16 bit option? much smaller files and pretty much same performance
also, when saving all passes i think the Denoised render is ignored (i.e. it is not saved)
Dingbat
bump
This is in the next release of the plugin.
Dingbat
fantastic - thank you Paul
just checking - did you see this bit?
Dingbat wrote:also, when saving all passes i think the Denoised render is ignored (i.e. it is not saved)
Dingbat wrote:fantastic - thank you Paul
Yes, that is fixed in the next release already.
Thanks for the report.
Dingbat
hi Paul,
thanks for the latest update. i tried the 16 bit exr option and the Denoised layer is still missing
do i need to do something other than enable Denoise to have it show up?
attached shows available layers in Fusion Studio
EDIT: same issue in Affinity Photo - no Denoise pass
Does this version of the plugin resolve your issue please? https://render.otoy.com/customerdownloa ... STUDIO.exe
Dingbat
hi Paul yes this version works as expected
thank you
