No Octane tags
vchili
I have the latest demo of Cinema 4D running and bought Octane. I installed the plugin into the plugins folder (left the latest version, c4dOctane-R2023.xdl64 in there). I do not have any Octane tags available under Tags? Is that normal? I tried downloading and installing again and it's still the same.
Thanks!
VC
in general, this is happening if the installation is not correct.
Please, go to c4d menu Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
Please, also share a screenshot like this one, that shows both the c4doctane directory opened, and the entire installation path, thanks:
ciao,
Beppe
vchili
Hi, here is the console output and the screenshot:
Loaded Octane DLL:OctaneRender Studio 2021.1.6 version:11000600 SDK:2021.1.6
OctaneRender for Cinema 4D 2021.1.6-(R7) built for:20230 C4D vers:2023100
C4D:2023100 comp:[EpicRenderBox1] OS:[WINDOWS 64 BIT] Windows 11, 64 Bit, Professional Edition (build 22621) versType:10
CPU:[AuthenticAMD, stepping 2, model 1, instruction family 15] speed:4.7 GHz numOfCpu:24Ht
Plugins:[cadexchangeconfig substanceconfig addons advanced_render alembic aligntools archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4dOctane-R2023 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing cyctypes deltamush deployment dropzone dwg dwgobjects dynamics exchanges expressiontag fbx gltf gorillacam goz greyscalegorillahub hair hdrilink i_skp interop interop_forger io_forger io_obj lightkit3 lighttypes metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor2 objects onlineupdater pbd_simulations physx_hybrid pluslibrary projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader signal sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions redshift4c4d ]
NVAPI initializing...
NVAPI Version: NVidia Complete Version 1.10
Nvidia driver version:526.98 [r526_91]
Loaded 175 osl scripts from dir:C:\Program Files\Maxon Cinema 4D 2023\plugins\c4doctane\res\osl_scripts
Thanks!!
bepeg4d wrote:Hi,
ciao,
Beppe
Installed files are not from demo version. Check the downloaded archive again.
here is the direct link to the latest Demo version:
https://render.otoy.com/plugindownloads ... .1_win.rar
Please, also change the name of the folder from Plugins to plugins in lowercase:
ciao,
Beppe
