When I change UV, LV is not refreshed properly. After a UV change sometimes LV refresh but correct UV information is not updated.
I have to hide and unhide the object to trigger it.
Is there any settings about it or any way to fix this?
LV is not triggered / updated after UV changes
What kind of UV change you're doing? It will update if any change is detected. Otherwise will not because of unnecessary updates. This is internal workflow of it.
I just made some tests. Yes it refreshes normally but if the object is under a Subdivision Surface it doesn't.aoktar wrote:What kind of UV change you're doing? It will update if any change is detected. Otherwise will not because of unnecessary updates. This is internal workflow of it.
Edit: and "Instance object" sometimes does not trigger
Edit 2: if object is under Symmetry, LV is not triggered as well
There are nothing to do for some specific cases.
