OctaneRender for Maya 2021.1.6-20.21 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2018, 2019, 2020, 2022 and 2023 64-bit on Windows and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2021
Changes since version 20.20:
  • Minor bug fixes...
NOTE: If you plan to use this plugin, DON'T UPDATE the Bifrost version from the standard one installed by a Maya installer to 2.5! The Bifrost 2.5 SDK/API is completely incompatible with previous one, thus you will not be able to load this plugin.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
hgarrou
I've had no luck with Maya Octane 1.6.20.20 or...20.21 on Maya 2023.2.
Does this sound normal?
BK
hgarrou wrote:I've had no luck with Maya Octane 1.6.20.20 or...20.21 on Maya 2023.2.
Hi Hgarrou,
Thanks for the post. Would you please check the Bifrost version from Plugin Manager?
Press the (i) info button. Autodesk have made huge changes with Bifrost on Maya 2023.2 update.
So OFM v20.20 or v20.21 won't be compatible if it is v2.5.
A workaround is to Uninstall from the Control panel and install the Bifrost 2.4 or revert back to Maya 2023.1 update.
Let us know how it goes!
Cheers
Kind Regards
bk3d
hgarrou
Thanks bk.
I suspected that was the reason.
Yes, I had bifrost 2.5.
And rolling back maya worked like a charm.
BK
hgarrou wrote:Thanks bk.
Awesome! thanks so much for confirming!
cheers
Kind Regards
bk3d
Some Windows installer-files appeared to be corrupt, so I've re-uploaded and replaced the download-links. If you had troubles when installing the plugin, just re-download the installer and try to install again.
IRONIC3D
Hi JimStar
Any chance of updating for use with latest BiFrost 2.5.x? the API changes that Autodesk introduced in 2.5.x are mainly type changes which they claim are backward compatible, which isn't really true, one plugin wasn't working because of the type change from Amino::object to object. but making that change resolved the issue without a problem (https://help.autodesk.com/view/BIFROST/ ... 5_0_0_html). The 2.5.x release is a strong one and useful. Having to roll back to 2.4 whenever using Octane is not ideal!!!
Thank you
BK
IRONIC3D wrote:Hi JimStar
Thank you
Hi Ironic3d,
We are actually concerned implementing Bifrost 2.5 would break our current Stable branch!
So, we plan to add Bifrost 2.5 support in the next 2022.1 XB4-21.10 branch release.
cheers
Kind Regards
bk3d
Jolbertoquini
Hi Jim,
Since the latest version 2021.1.5 the ocio connection on the imager is completly broke on 2018's versions could you update this issues?
we was using without aces but now we wanted the plug has actually issues.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Jolbertoquini wrote:Hi Jim,
Best,
JO
Just fly Bikram should me we NEED to set EXR to work otherwise it doesn't activate I was confused cause the beta plug was working at png I guess was wip.
so it's all good!we don't have to export scenes. Thanks Bikram for clarifing to us.
Best,
JO
Locked
