HI,
Anybody have tested last grow feature IVY in TYFLOW ?
All is ok with Tyflow, but when I try to use preset flow "Simple Ivy flow", it crash Max when octane render viewport open.
TYFLOW and IVY
bump !
Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow"
Yep. It crashes for me too. Can anyone look at the attached scene. I posted this problem on ty forum.HHbomb wrote:Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow"
- Attachments
- tyflow ivy crash.zip
- (50.32 KiB) Downloaded 170 times
- neonZorglub
Hi coilbook,coilbook wrote:Yep. It crashes for me too. Can anyone look at the attached scene. I posted this problem on ty forum.HHbomb wrote:Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow"
Thank you for the scene.
This will be fixed in the next release.
Can you please look into Legacy and Direct modes for itoo forest and animation used within itoo forest? We have to use Direct if itoo objects are animated but then it causes very long evaluation times.neonZorglub wrote:Hi coilbook,coilbook wrote:Yep. It crashes for me too. Can anyone look at the attached scene. I posted this problem on ty forum.HHbomb wrote:Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow"
Why cannot we manually add itoo forests to legacy or to direct modes? That's why if we have 10 itoo forests and only one has animated objects, we can make nine static itoo forests as legacy and the last one as direct. Then octane won't have to rebuild them every frame. Thank you
