TYFLOW and IVY
HHbomb
HI,
Anybody have tested last grow feature IVY in TYFLOW ?
All is ok with Tyflow, but when I try to use preset flow "Simple Ivy flow", it crash Max when octane render viewport open.
coilbook
I will test it. I think octane get confused when new faces appear in real time while octane viewport is open
HHbomb
bump !
coilbook
HHbomb wrote:HI,
Where can I find "Simple Ivy flow"?
HHbomb
Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow" :-)
coilbook
HHbomb wrote:Hi, create a tyflow object, open tyflow window, Right click on window's empty area and choose "preset flow" then "Simple ivy flow" :-)
Yep. It crashes for me too. Can anyone look at the attached scene. I posted this problem on ty forum.
tyflow ivy crash.zip
(50.32 KiB) Downloaded 177 times
neonZorglub
Hi coilbook,
Thank you for the scene.
This will be fixed in the next release.
coilbook
Hi coilbook,
Can you please look into Legacy and Direct modes for itoo forest and animation used within itoo forest? We have to use Direct if itoo objects are animated but then it causes very long evaluation times.
Why cannot we manually add itoo forests to legacy or to direct modes? That's why if we have 10 itoo forests and only one has animated objects, we can make nine static itoo forests as legacy and the last one as direct. Then octane won't have to rebuild them every frame. Thank you
Return to “Autodesk 3Ds Max”
