OctaneRender for DAZ Studio 2021.1.6 - 76 [OBSOLETE]
Moderator: BK
toby_a
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for DAZ Studio - TEST (ie. pre-release) and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you are running the latest version of the OctaneRender for DAZStudio plugin.
3) If you experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
This also resolves the "COULD NOT INITIALISE IN-MEMORY DB!" error on startup and a number of other issues.
4) If the Save button is disabled when using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
5) If rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
6) If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 3 above.
7) If you get a "Could not save a frame for X times!" - please refer to the thread at
for potential solutions.
8) If you get a "Bogus Scene Path" error - this is due to having an apostrophe in the filepath of a texturemap (so store your textures in foldernames which do not have apostrophes).
9) Octane panel title bar is off the screen and cannot be closed - click anywhere on the Octane panel and then press Alt-F4.
10) Rendering animation results in the scene emitter intensities changing - this is because rendering animations is done in "Final" mode, where meshes are merged. To resolve this, UNTICK the Preferences->Use Combined Mesh, or ENABLE the Surface Brightness pin on each of the emission materials in the scene.
11) Denoiser is not working - make sure you have a graphics card selected for Denoising in the System tab->Open Device Settings window, and that you are using the Path Tracing kernel.
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
13) Octane panes do not appear on the screen (ie. they open off the screen) - Main Menu Bar->Window->Workspace->Select Layout->Accept (you might choose a different layout to the current layout to make this work).
KNOWN ISSUES AWAITING RESOLUTION
1) Panoramic camera and OSL nodes are not currently supported.
2) Templating is not currently working for specular and roughness maps from Iray materials. - FIXED (please report any issues)
3) UDIM Tiles are not currently supported. - FIXED (please report any issues)
4) Some of the newer OctaneRender material and texture types are not supported. - FIXED (please report any issues)
5) VDB volume and volumetric spotlight nodes are not currently supported,
DAZ Studio Version
DAZ Studio 4.8 or later on Windows 8, 10 or 11 64bit
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped.
Also, make sure you use an Nvidia Studio driver of version 451.xx or higher.
Network Rendering
For Network Rendering, you must use the OctaneRender Enterprise Node release from the Octane Standalone forums/download page which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Enterprise 2021.1.6 Render Node builds.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win 8, 10, 11)
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- DAZ Studio version
- OctaneRender for DAZ Studio version (e.g. 2021.1.6_76)
- The most important part of resolving a problem is being able to reproduce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Changes since 2021.1.6 - 75
  • Image Tiles node support
    • This allows you to create a texture from multiple image files. Each image is assigned a range of UV coordinates based on its position in the grid.
    • The Genesis 8 characters, at least, have UV coordinates that are set up to be used in this way, so you can create a single material that covers all of the skin surfaces of a figure.
    • At present there is no automatic support to help you do this - you will need to manually set up an Image Tiles node for the diffuse images, the normal images, etc.
  • Image file name replacement during animation can be disabled
  • Step up/down buttons added for OCIO View and Look selection
Download Links
Please feel free to report any issues you encounter.
Happy rendering
Your OTOY team
Tugpsx
Love the new image preview feature, this opens options to make visual changes and prompts for action. In one case I realized that I needed to create a normal map from my image and was able to do so and save in the same location.
mikmod
Hi!
I noticed some little lingering QoL issues with the plugin, like pressing Delete within the shader node view - that will not delete the selected node, but the actual object in Daz scene (if selected). I shudder to the thought, what happens, when no node is selected... :)
Also, editing the numbers in the fields seems a bit quirky - sometimes the field doesn't seem to be editable, despite nothing actually locking the field up. At the same time, I can move the horizontal sliders just fine. It happens while the Octane Viewport is active/rendering. AN example would be Materials section of Octane window, where many numbers and sliders for shaders exist and are accessible.
RGUS
Tugpsx wrote:Love the new image preview feature, this opens options to make visual changes and prompts for action. In one case I realized that I needed to create a normal map from my image and was able to do so and save in the same location.
Where is this feature?
I've been hunting for ages looking for it, but can't find it.
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
toby_a
mikmod wrote:I noticed some little lingering QoL issues with the plugin, like pressing Delete within the shader node view - that will not delete the selected node, but the actual object in Daz scene (if selected). I shudder to the thought, what happens, when no node is selected... :)
Hi, yes, you're right, there is definitely something dodgy about how the keyboard works in the node editor. It seems like the keyboard shortcuts when a node is selected don't work at all. I'll take a look at it.
Thanks for the report.
mikmod
Thank you!
I know I'm being a pain, but while mentioning QoL improvements, I forgot to point out, there's probably no Undo/Redo feature in shader node editor, right? At least not under Ctrl+Z/Ctrl+Y shortcut keys?
toby_a
mikmod wrote:Thank you!
Unfortunately there is no undo functionality in the node graph editor. This is on the big list of features and we'll get to it at some point, but probably not soon as it requires a major overhaul of how the plugin manages changes internally.
Tugpsx
RGUS
Oh`, there it is... I thought that had always been there, those three little dots are sometimes hard to resist clicking on.
Thanks.
RAM: 64GB
Tugpsx
Thanks.[/quote]
Grab program "Materialize" and you can create the missing maps to produce great materials.
Return to “DAZ Studio”
