What's going on here?
https://www.dropbox.com/s/lqo0y0zc7sl5n ... 9.mov?dl=0
In my case the images are no longer rendered ready. The process just keeps running.
The problem only seems to occur when the current user login, on Windows, is locked and logs back in. (Win + L).
Maxon Cinema 4D R26.107
Octane for C4D 2022.1-XB2_R2
Win 11 (21H2)
Rendering does not finish
Open Console window and paste the all messages here. Probably it's about denoiser usage.
So the problem occurs only in version 2022.1-XB2_R2.
no matter if the AI Denoiser is active or not.
2022.1-XB1_R3
2022.1-XB1_R3
2022.1-XB2_R2--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=22
Export materials time= 25.153 ms
Collect objects time= 12.151 ms
Mesh creation time = 1077.384 ms.
MB:0/0 ST/MOV:0/3678 Nodes:7382 Tris:5.173m DispTris:0 Hairs:0 Meshes:3k
Textures Grey8/16:11/1 Rgb32/64:15/2
VRAM used/free/max:3.897Gb/4.013Gb/11Gb Out-of-core used:0Kb RAM used:20.017Gb total:63.927Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0sec. updateTM=0sec. renderTM:668.37sec. totalTM:676.899sec.
Buffer type must be HDR float if not using false color for cryptomatte passes
Tonemapping the all passes tm:0.009
pass [Denoised beauty] ID:43 not found...
Displaying passes in tm=0.02
Passes saved in:0.223sec.
2022.1-XB2_R2 with disabled Spectral AI DenoiserMulti-threaded material conversion, thread count=22
Export materials time= 26.305 ms
Collect objects time= 10.661 ms
Mesh creation time = 1057.756 ms.
VRAM used/free/max:3.619Gb/4.666Gb/11Gb Out-of-core used:0Kb RAM used:21.89Gb total:63.927Gb OpenGL free/total:0/0
Export materials time= 24.921 ms
Collect objects time= 9.416 ms
Mesh creation time = 1129.969 ms.
VRAM used/free/max:3.497Gb/5.064Gb/11Gb Out-of-core used:0Kb RAM used:21.271Gb total:63.927Gb OpenGL free/total:0/0
How is doing that with 2022.1 XB3-R3? Please send your scene if still same on this!
will be tested tonight. Had not noticed that there is a new version.How is doing that with 2022.1 XB3-R3?
With version 2022.1-XB3_R3 everything is ok
Export materials time= 35.206 ms
Collect objects time= 10.119 ms
Mesh creation time = 1107.959 ms.
VRAM used/free/max:3.892Gb/3.99Gb/11Gb Out-of-core used:0Kb RAM used:19.534Gb total:63.927Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0sec. updateTM=0sec. renderTM:670.137sec. totalTM:678.064sec.
Tonemapping the all passes tm:40.527
Displaying passes in tm=3.273
Passes saved in:0.195sec.
