Prevent from casting shadow on other objects.
spartan00j
How do you prevent a object from casting a shadow. Or casting a shadow on a selected object.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Erick
in the Material Setup, bottom section, you can tick or un-tick the Shadow Visibility.
Setup:
With Shad.Vis. ticked:
Un-ticked:
Hope that helps.
spartan00j
Erick wrote:Hi,
Setup:
Un-ticked:
Hope that helps.
Thank you,
Also is there a way to stop an object from showing up in a reflection?
I have an object. I want it to be glossy. But not reflecting anything around it.
So glossy without reflecting.
Win 11
128GB RAM
RTX 3060 TI
spartan00j wrote:
Erick wrote:Hi,
Setup:
Un-ticked:
Hope that helps.
Thank you,
Regarding the Shadow Visibility - there is also the Mesh->Shadow Vis. checkbox that can be turned off. For reflections, I don't think this is possible, although you could play with the material reflection settings.
spartan00j
face_off wrote:
spartan00j wrote:
Erick wrote:Hi,
Setup:
Un-ticked:
Hope that helps.
Thank you,
Okay,
Thanks Paul
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
