Hi Paride,
Do you have a sample scene with a volume spot light where it looks like in the image attached as a blue sport light.
It seems there is no connection between volume, light, light spot, cone size. Thank you!
problems with volume spot light
- paride4331
Hi coilbook,
You can use the volumetric spotlight or a photometric spotlight that octane now supports.
Regards
Paride
Regards
Paride
- Attachments
- spot03.zip
- (98.52 KiB) Downloaded 124 times
- spot02.zip
- (128.52 KiB) Downloaded 121 times
- spot01.zip
- (131.2 KiB) Downloaded 121 times
- neonZorglub
Support for photometric lights is also available from 2021.1.5 - 22 / 23.coilbook wrote:Thank you. And photometric spotlight are only supported in 2022 version?paride4331 wrote:Hi coilbook,
Regards
Paride
The photometric spotlight might be currently a bit more noisy than the Octane volumetric spotlight.
This will be improved in a future release.
When starting a new scene, the Octane volumetric spotlight is probably a better choice.
Note that you can have control of the 'hardness' of the light cone (as with the 2 angles of the photometric spotlight hotspot / Falloff),
using a 'Spotlight' map in the Distribution' of the black body emission:
See the red spotlight here: Thanks
Thank you!neonZorglub wrote:Support for photometric lights is also available from 2021.1.5 - 22 / 23.coilbook wrote:Thank you. And photometric spotlight are only supported in 2022 version?paride4331 wrote:Hi coilbook,
Regards
Paride
