I have an animation I am working on where a cutting boolean moves through an object to reveal the inside. However, when I render in Octane, it does not show the element being cut. Is there something I'm missing to make this work, or any workaround?
Thanks in advance!
Andy
Animating Boolean
Probably need to define the bool object and the target object as "reshapable proxy" in the Octane object properties. Objects default to "scatterable/movable".
Side note: I usually put bool objects in their own collection. Then for the render, I make sure that the collection is turned OFF. Otherwise, the bool object causes render weirdness.
My friend. I am sending you the biggest e-hug/bow/praise that the internet has ever seen! This worked a treat!protovu wrote:Probably need to define the bool object and the target object as "reshapable proxy" in the Octane object properties. Objects default to "scatterable/movable".
Thank you so much for your help!
