Link object motion to texture transform?
GOTHACOM
Hello,
I'm wondering if it's possible to control the transformations of an Octane procedural texture with the motion of an external object?
I tried to add a standalone Texture Locator and use the embedded Octane Projection with the procedural, but I get an error:
Tried to access null node pin
Tried to access null item
Tried to access attribute via invalid ID A_VALUE (185)
We can't evaluate items of a different version (version 0)!
Is there an alternative way to do that?
Thanks.
Regards.
G
funk
It looks like Modo texture locators only work for Octane image nodes.
The modo plugin allows you to connect modo channels to Octane channels using the method described here:
https://docs.otoy.com/ModoH/ModoPluginM ... annels.htm
I have attached a file showing you how I'd control an Octane node from a modo item (locator). You can move/rotate/scale the locator, and this will update the noise node.
octane_procedural_external_control.7z
(11.17 KiB) Downloaded 129 times
GOTHACOM
Thanks man, my bad I haven't thought to expose floating input channels in the schematic... I wasn't aware it was possible at all.
Thank you very much!
G
Return to “Foundry Modo”
