I used to use "Visble in camera" a lot in the past, and the result of rendering is that the item is hidden but the shadow is still displayed on other items,
but in the latest version, using this function will make the item and the shadow hidden at the same time.
Is this feature canceled, or moved to other options?
The new version "Visble to camera" does not work
- paride4331
- bakanopower
Wow I have never used this node before, thank you so much. learned new knowledge through you.jobigoud wrote:Can you use the Raytype switch node plugged into the material opacity? It should give more control.
- bakanopower
Thanks for your reply, but in my version it shows like thisparide4331 wrote:Hi bakanopower,
Regards
Paride
I used the 3dsmax 2021
- paride4331
Hi bakanopower,
Which plugin version are you using?
Regards
Paride
Regards
Paride
- bakanopower
My plugin version is 2021.1-12.07paride4331 wrote:Hi bakanopower,
Regards
Paride
- paride4331
