Scatter in volume shader
Houdini Integrated Plugin
davidyannick_1
I'm trying to recreate the scatter process for pyro volumes, I've done it in Arnold, is there a way to bind temperature, density, scatter in an octane shader ?
juanjgon
Perhaps you could attach an example scene and some screengrabs about what you are trying to do. This could help to figure out how to render this volume.
davidyannick_1
juanjgon wrote:Perhaps you could attach an example scene and some screengrabs about what you are trying to do. This could help to figure out how to render this volume.
The graph is very heavy but for instance here I need to bind the scatter field in the shader (here in arnold) is it possible in octane shader ?
juanjgon
I'm not sure, to be honest. These are the link to the volume medium docs, in case it could help:
https://docs.otoy.com/StandaloneH_STA/S ... ediums.htm
https://docs.otoy.com/HoudiniH/HoudiniP ... Volume.htm
https://docs.otoy.com/HoudiniH/HoudiniP ... 20Ramp.htm
davidyannick_1
juanjgon wrote:I'm not sure, to be honest. These are the link to the volume medium docs, in case it could help:
ok thanks gonna check this :)
Return to “Houdini”
