cannot access material graph in assembly
jwfvr
hi - I need to create a lot of grassy terrain for some archviz work and I have a problem - I made an assembly using some grass presets that have octane overrides - when I use the assembly in a scene, everything works fine, the material with the override shows in the shader tree, but when I click on the override it does not take me to the material graph as usual - and if I expose the assembly, I can get to the group of presets, but that is as far as I can go - I cannot seem to access the material I created for the presets (that are then used in the assembly) am I doing this wrong? is there a way to access the material? I would like the ability to adjust the material further on a per-project basis. thank you
Hi - can you send me the scene please, and tell me the version of Modo that you are using (as Modo15 changed that way presets were loaded).
Return to “Foundry Modo”
