Universal shader issue
firesprite
Here is the screenshot with different render results but scene is the same. Can someone explain what happens?
Or it is all known issue and i just missed something?
Here is the link to test scene, check this one and you're get different results using universal shader!
https://www.dropbox.com/s/0x4j46bg5jl51ty/test.c4d?dl=0
firesprite
elsksa wrote:Hi,
I would not suspect an issue, from what I see from the screenshots. Eventually different material properties/attributes. On the glass cylinder, the roughness seems to differ.
Could you screenshot both Universal Material properties, respectively?
this is the same scene with all the same properties and different results, you can download this test project and check it
Ilius
Im having the same issue with all my old projects that im trying with the new octane now
I've used Universal Material for everything, even for glass.
It used toe be as easy as "unchecking" Albedo and getting rid of Metallic reflection and voila, the Universal Material acted like a specular.
But not anymore.
Now you have to really use a Specular material.
Is that on purpose?
to fix the issue, please go to Universal material/Transmission channel, and change the type to Specular instead of Diffuse.
In previous versions,Specular was the default type, but there was an issue with Mix Material Diffuse+Glossy conversion to Universal, for leaves and similar translucent flat objects:
viewtopic.php?f=85&t=78663&p=406664&hil ... se#p406664
So has been set to Diffuse, and you need to set the type to Specular, if the Universal material has to behave like a Specular material.
ciao,
Beppe
hazenkind
The old Materials are only there for legacy reasons i guess? All that "old" stuff should have a "legacy" Label.
Ilius
its always those small changes that f**k up your workflow :D
i know i could just read up whats changed in the log, but it would be nice to have a function like cinema itself, where new stuff is highlighted in yellow
firesprite
Thanks guys for all replies, now i got what the problem was and for sure i missed that checklist with updates about universal material new settings(
