Hello,
for a 8000x9000 px render output scene rendering process does not start (sometimes it does in a normal time period but mostly it does not)
I have a scene that include 2 Forrester Multicloner objects. Every take alter their values to create different procedural objects.
Yesterday I've left the machine to render all but at it was in the "updating" phase for 6 hours so nothing was rendered.
Now I wanted to take render and currently 35 minutes passed. Logs are below:
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=30
Export materials time= 359.775 ms
Collect objects time= 12.323 ms
Mesh creation time = 19.485 ms. (there is a note below for this topic)
While "Updating" phase Cinama 4D CPU usage is around 0%-1%
GPU Load is 100%
notes:
1) 4 days ago I updated windows and also nvidia driver(511) today I uninstall last windows update and reinstall previous driver version of nvidia but I guess It does not work.
2) I tried "Enable out of core for texture" option and I've set as RAM usage limit:2048 / GPU load room:2048 but it didn't effect the situation (I really don't know what is this but I tried)
3) I've isolated Forrester Multicloner object with a new document and this problem is still happening. If I convert it to a single mesh render(connect and delete) is starting in considerable time. But I can't use this workflow because all scene is procedural and my 40 takes alters its values. Also converting to a mesh takes time and I can't make them all (file size exceeds 15 GB in that situation) One of Multicloner object's converted mesh version has 12M polygons.
C4D 25.117
Octane 2021.1.1 (live viewer window title is 220.2.5-R3 I don't know why. But live viewer's tab title is 2021.1.1)
1080 TI
Windows10
32 GB RAM
I have 80 GB free space too
I know many things may cause this kind of issue but I wanted to write down maybe it is known situation.
thank you
About a stucked rendering process issue
