VDB Volume Object not working on M1 / PR13
atoyuser1
Using R24 for both, here is a VDB Volume on a Intel Macbook Pro, Big Sur, PR11:
Intel Big sur PR11
Intel Big sur PR11
Here is the same C4D file on M1 Monterey PR13:
M1 Monterey PR13
M1 Monterey PR13
Also created a screencap:
Intel Big sur PR11 Screencap
As you can see, the whole scene disappears. I'm not sure if this is a PR13 bug or an Apple Silicon M1 issue, since PR13 won't work on Intel Big Sur
Any clues? Thanks!
atoyuser1
This also occurs with Fog Volume, R24:
Fog Volume R24
Fog Volume R24
thanks for the report.
it is a known issue in PR13 SDK, and will be fixed in the next update.
ciao,
Beppe
atoyuser1
bepeg4d wrote:Hi,
ciao,
Beppe
thanks Beppe
atoyuser1
FYI no longer works on TurbulanceFD either.
Tested the same project file on older mac PR11, and it renders fine.
Assume it's the same bug
klaushuang
bepeg4d wrote:Hi,
ciao,
Beppe
When will it actually be compatible with M1 chips? The CURRENT PR13 crashes regularly.
