Using R24 for both, here is a VDB Volume on a Intel Macbook Pro, Big Sur, PR11:
Here is the same C4D file on M1 Monterey PR13:
Also created a screencap:
As you can see, the whole scene disappears. I'm not sure if this is a PR13 bug or an Apple Silicon M1 issue, since PR13 won't work on Intel Big Sur
Any clues? Thanks!
VDB Volume Object not working on M1 / PR13
thanks for the report.
it is a known issue in PR13 SDK, and will be fixed in the next update.
ciao,
Beppe
ciao,
Beppe
- klaushuang
Hi,bepeg4d wrote:Hi,
ciao,
Beppe
When will it actually be compatible with M1 chips? The CURRENT PR13 crashes regularly.
