Hi I´m from slovakia.
So , I have problem with exporing maps from 3ds max. I use max2octane.
When I have only one chanel, or diffuse map but when I use composite, Multi/Sub-object or UVW map. In octane it is without colors.
What I have to do ?
3ds max mapping
- Jaberwocky
Molki
I did a quick experiment.Used a Multi/sub object material in max
I assigned plain colours to 10 of the 12 channels and images to the other 2.
I assigned a different channel numbered 1 through 12 to 12 poly faces of the cube.
They seem to come across ok
See Screen Shots attached
I used Jimstars unofficial max importer for this experiment.
