Setting AOV custom in object parameters
Houdini Integrated Plugin
HandcraftedMedia
Is there currently a way to set the "custom" (1-10) AOV pass for an object, similar to the old render layer settings? I see that the cinema4d plugin has that option under the octane tag, but can't seem to find a similar option in Houdini?
juanjgon
HandcraftedMedia wrote:Is there currently a way to set the "custom" (1-10) AOV pass for an object, similar to the old render layer settings? I see that the cinema4d plugin has that option under the octane tag, but can't seem to find a similar option in Houdini?
Let me investigate it, I'm not sure how this feature works, so probably is missing in the Houdini plugin.
juanjgon
I've added the OBJ level custom AOVs for the next plugin build.
Thanks for reporting this limitation!
HandcraftedMedia
Amazing, Thank you!
Return to “Houdini”
