AOV system has set me back in learning
RSgraphics
Hey all.
I'm looking for a clear and comprehensive walkthrough of the new AOV rendering system in octane and c4d using the aces workflow in english.
Before:
1. Set up aces
2. Render out with LDR 8-bit / OCIO: Output sRGB
3. Take two seconds to select which passes i want
The above was a simple workflow that worked well.
Any ideas how i can get back up and running?
P.S. Im more of an artist than a technician. Without intuitive software im a dead fish in the water.
in R6(latest build), there's a great AOV manager window. Have you checked that. Also it has making your presets for next usages.
ceen
too bad Otoy is not able to make short introduction videos for fundamentally new features but the internet helps out.
This video is a great start to new AOVs in my opinion:
https://www.youtube.com/watch?v=cx-eLemdNxo
The system has improved in fact
3080ti
jayroth2020
The following is a snippet from the upcoming documentation release. This snippet is not exhaustive, but it does provide enough of an overview to get started with the new AOV system. Please note this information is copyrighted, trademark protected, etc. by Otoy.
Arbitrary Output Variables (AOVs) are artist-specified render and data passes generated by OctaneRender® that can be used for compositing, checking shader output, debugging issues, etc. AOVs can output a variety of different image output passes, as well as include data passes such as normals, object positions, material IDs, motion vectors and more. AOV nodes can create simple composites inside of Octane, which can be seen in the Live Viewer and output at render time, as well as output as freestanding files to be used in external compositing applications. These composites are managed with AOV Groups and Presets, available from Render Settings > Octane Renderer > AOV Groups and Render AOV Group tab. Supporting the AOV nodes are additional special material nodes, available in the Node Editor and Custom AOV options have been added to materials and to the Octane Object tag, to extend the functionality of the AOV system.
Octane Renderer Node
The Octane Renderer node houses the contents of the Octane Renderer Render Settings panel, inclusive of the Main tab, Overwrite Kernel Settings tab, AOV Groups tab and the Render AOV Group tab. For AOV work, the AOV Groups tab and the Render AOV Group tab contain the necessary control settings, and along with the AOV Node Editor. The Octane Renderer node allows for two input connections: Render AOV and Composite AOV, discussed below. Multiple inputs of these two types are supported. There can be only one Octane Renderer node per scene.
Render AOVs
Render AOVs (which include Auxiliary, Beauty, Custom, Denoised, Info, Light and Render Layer AOVs) are isolated RGB, RGBA and data components that can be used in Composite AOVs (via the Composite Output Layer node connected to the Render AOV Output nodes). Render AOVs are equivalent to the Render Passes of previous versions of Octane. Render AOVs are managed via the Render AOV group tab. Render AOVs are directly connected to the Render AOV input pins on the Octane Renderer node.
Composite AOVs
Composite AOVs are composites that are constructed with Render AOVs via the Render AOV Output nodes which are connected to Composite Output Layer nodes. Composite AOVs include the functionality of the AOV Output Group node, although this node is also available separately in the nodegraph (Octane Standalone requires this node to be connected between the Render Target node and the Composite AOV Output node. Composite AOVs are managed via the AOV Groups tab. This tab can be used to create AOV presets, and add additional Composite AOV pins to the Octane Renderer node.
AOV Node Editor
The Octane AOV Node Editor (seen in the illustration below) is used to build compositing networks that can then be rendered out in addition to standard Octane renders, either as separate files or as layers within some formats, such as EXR(Octane). The AOV node editor is the same node editor that Octane uses for materials; that said, it is best to keep the AOV nodegraph separate from any material nodegraphs in the scene for readability and maintenance purposes.
The AOV node editor is accessed via Render Settings > Octane Renderer > Render AOV groups tab > Node Editor button (a new AOV system button was added to the top of the Octane Node Editor workspace as of the 2021.1 release to allow for easy switching). A traditional Cinema 4D layered style representation of the AOV environment is also presented in the AOV Groups tab.
Global Texture AOVs
Global texture AOVs allow you to apply a texture to the whole scene including or excluding the environment. Global Texture AOVs are rendered as info AOVs, which means that the info AOV settings are applied to them as well. You can overwrite the alpha channel with your own texture, or use the default behavior which is equal to the alpha channel of the other info AOVs. Render AOV Output nodes can reference Global Texture AOVs in composites as needed.
AOV Composite Example
The images below are the result of three contributing Global Texture AOVs, used to build up the wireframe blend on the first image, and the depth fog on the second image.
The illustration below shows the node graph for the composite images above directly from Octane:
Each of the Global Texture AOVs have standard material nodes as inputs. These subgraphs are used to build up the effects that are then blended into the Render Pass AOVs connected into the Composite AOV Output Layer nodes and then into the Composite AOV Output nodes. These nodes are connected to the Composite AOV pins of the Octane Renderer node for final output.
RSgraphics
Wow
Ok
So the video was helpful. Thank you.
The copy from the manual, well…your talking about a lot of new things. Some things I’ve never heard of before. Sure I get the basic idea of arbitrary passes but to try and visualize how this all works from your text is a bit demanding on your users. Cant someone record a walk through? I have to say cg artists are a busy group of people. You have the opportunity to help us out by making it simpler for us and quicker for us. Just saying. But thanks to you as well. Any info I can get will help. And it seems well written which is a great improvement to the octane manual. Looking forward to the final update to the manual! :)
SSmolak
Hightechmech
Thanks guys for the replies but I also have the same issue, I simply need the AI Denoiser and Cryptomatte passes but cannot get them working correctly. The denoiser reminder comes completely black and the cryptomatte one has totally no information, both material & object nodes. I also watched the videos but couldn't find anything related to what I am looking for.
pinarer
I agree. A video should be released when there are big changes and go through all the steps. Those manuals are not that helpful. Learning from a video instructions much valuable.
I demand this as well :)
