OctaneRender for Maya 2021.1-20.8 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2020.2
Maya® Version Requirements
This release will work with Maya® Versions 2018, 2019, 2020 and 2022 64-bit on Windows and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2021.1
Changes since version 20.7:
  • Implemented the support of dynamic size for Octane's nParticles shapes.
  • Implemented few lost AOV attributes in materials.
  • Implemented Octane scatter-on-surface for Maya "mesh" nodes.
  • Implemented Octane scatter-in-volume for "octaneVolume" nodes.
  • Demo version is now available.
  • A couple of minor fixes and improvements...
Known issues:
You may experience some crashes when updating "mesh" nodes in "scatter-on-surface" mode. This is some Octane engine issue, not related to the plugin. Does not affect any functionality other than the new geo-scatter. Should become OK after gets fixed on the engine side...
Materials are not supported for instances in the new "geo scatter" functionality so far, I'll add this functionality in the next plugin release.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
g0ll4m
I just tried to install this version and got this error.
Windows 10
Maya 2024.2
2 RTX 4090s 192 gb ram
Weird. I can't reproduce it on my side, works OK...
I will investigate it further and release a quick-fix if there is some issue on a plugin side...
g0ll4m
I rebooted my computer and tried again and it works, so false alarm.
Windows 10
Maya 2024.2
psultan
Having an issue installing on Linux.
With bifrost off...error in script editor...
// Error: file: /usr/autodesk/maya2022/scripts/others/pluginWin.mel line 316: Unable to dynamically load : /usr/otoy/ofm_vre/2022/plug-ins/OctanePlugin.so
/usr/otoy/ofm_vre/2022/plug-ins/OctanePlugin.so: undefined symbol: _ZN7Bifrost3API11StateServerC1Ev //
// Error: file: /usr/autodesk/maya2022/scripts/others/pluginWin.mel line 316: /usr/otoy/ofm_vre/2022/plug-ins/OctanePlugin.so: undefined symbol: _ZN7Bifrost3API11StateServerC1Ev (OctanePlugin) //
With bifrost on there is a fatal crash after a few seconds...
output from script editor:
// OctaneRendertm v. 2021.1 - 20.8, network rendering supported //
// Octane: plugin is activated. //
evalDeferred 'shaderBa11RendererMenuUpdate';
updateRenderOverride;
file -type mayaAscii;
// Result: untitled.ma //
output from shell:
Stack trace:
Octane::ApiOcioConfig::destroy()
/Bluearc/GFX/HOME/CHRLX/psultan/dev/3D/maya/maya2022/modules/linux/octane_20.8_2021.1/octane/lib/liboctane.so(+0x3dc6d8e) [0x7f6ec8cf9d8e]
initializePlugin(Autodesk::Maya::OpenMaya20220000::MObject)
Tplugin::primaryLoad(Tstring const&, Tstring*)
/usr/autodesk/maya2022/lib2/libOpenMaya.so(+0x34abed) [0x7f709360abed]
/usr/autodesk/maya2022/lib2/libOpenMaya.so(+0x349ce2) [0x7f7093609ce2]
/usr/autodesk/maya2022/lib2/libOpenMaya.so(+0x3495c2) [0x7f70936095c2]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0x98124) [0x7f708baf1124]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0xc22ab) [0x7f708bb1b2ab]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0xe387f) [0x7f708bb3c87f]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0xe2ebb) [0x7f708bb3bebb]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0xe4cad) [0x7f708bb3dcad]
/usr/autodesk/maya2022/lib2/libCommandEngine.so(+0xc23e1) [0x7f708bb1b3e1]
SophiaExecutable::evaluate(void*)
TcommandEngine::executeCommand(Tstring const&, bool, bool, TmelCmdResult*, unsigned int)
TscriptActionMixin::execute(Tevent const&, std::unique_ptr<TinterpreterResult, std::default_delete<TinterpreterResult> >*)
TcontrolScriptAction::doIt(Tevent const&)
Taction::performAction(Tevent const&, char const*)
Taction::doIt()
/usr/autodesk/maya2022/lib/libQt5Core.so.5(+0x2dd3b5) [0x7f7088eb13b5]
QmayaCheckBox::onOffChanged()
/usr/autodesk/maya2022/lib2/libExtensionLayer.so(+0x30fa73) [0x7f708c011a73]
QCheckBox::stateChanged(int)
/usr/autodesk/maya2022/lib/libQt5Widgets.so.5(+0x25aabc) [0x7f708ad24abc]
QAbstractButton::mouseReleaseEvent(QMouseEvent*)
QWidget::event(QEvent*)
QApplicationPrivate::notify_helper(QObject*, QEvent*)
QApplication::notify(QObject*, QEvent*)
/usr/autodesk/maya2022/lib2/libExtensionLayer.so(+0x32f9d6) [0x7f708c0319d6]
QCoreApplication::notifyInternal2(QObject*, QEvent*)
QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool)
/usr/autodesk/maya2022/lib/libQt5Widgets.so.5(+0x1c347c) [0x7f708ac8d47c]
/usr/autodesk/maya2022/lib/libQt5Widgets.so.5(+0x1c658c) [0x7f708ac9058c]
Locked
