Universal override?
BartvanDoornik
New Octane user here. Making the switch from Vray/Modo to Octane and love it sofar.
Would it be possible to have the automatic override go to a Universal material ? I am working with a PBR workflow and the Universal Material is perfect for that. Now i have to go change a bunch of nodes to get it right.
Main thing is that the Glossy Material doesn't support the metallic in PBR. Universal does.
If we can have options to choose how it will override that would be great.
i also made a bad quality video :)
Bart
2021-12-12 13-33-39.mp4
(22.82 MiB) Downloaded 1837 times
Hi Bart
This is on the "To Do" so will likely be in a future release of the plugin.
Greg
Seems like the override should convert a MODO principled material (with the Metallic channel) to universal (or whatever supports PBR, does 'standard surface material' in 2022?). I like how the plugin is smart enough to convert to glossy, specular, diffuse based on MODO material settings. I think converting to a metallic material if MODO diffuse is 0 and spec and fresnal are 100 would also make sense.
-G
CEO Sabertooth Productions
Co-Founder Pixel Fondue
Greg wrote:Seems like the override should convert a MODO principled material (with the Metallic channel) to universal (or whatever supports PBR, does 'standard surface material' in 2022?). I like how the plugin is smart enough to convert to glossy, specular, diffuse based on MODO material settings. I think converting to a metallic material if MODO diffuse is 0 and spec and fresnal are 100 would also make sense.
-G
Thanks for the input Greg.
BartvanDoornik
Thanks Paul, great it is already on the to do list.
As I understand the Universal material is a great material for pbr.
https://www.behance.net/gallery/1029482 ... arter-File
The new standard surface material looks great aswell. Nice!
Return to “Foundry Modo”
