How can I hide object scatter's source objects?
Sub forum for help and tutorials.
Delizade
Hello,
I have Object Scatter objects and under it there are 3 cubes.
Scatter object uses surface distribution. But I see 3 source cube on the scene too. I need to hide them from render. How can I do that?
thank you
you could hide the objects to scatter in a Null with red traffic-lights, then use an instance of the objects as source for the Octane Scatter:
Note that the Instance object must be set to Instance mode, Render Instance or Multi Instance modes are not working in this case.
ciao,
Beppe
Delizade
thank you.
Return to “Help / Tutorials”
