Unity Standard Cutout Shader is not working
Moderator: ChrisHekman
shorttrack
Unity Standard Cutout Shader is raising error
ArgumentOutOfRangeException: startIndex cannot be larger than length of string.
Parameter name: startIndex
System.String.Substring (System.Int32 startIndex, System.Int32 length) (at <695d1cc93cca45069c528c15c9fdd749>:0)
HelperScripts.Utility.ThousandSeparators (System.Single f, System.Int32 decimals, System.String separator) (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
OctaneUnity.RenderWindow.DrawStatusBar () (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
OctaneUnity.RenderWindow.OnGUI () (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect) (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEditor.DockArea.OldOnGUI () (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.IMGUIContainer.DoIMGUIRepaint () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIR.RenderChainCommand.ExecuteNonDrawMesh (UnityEngine.UIElements.UIR.DrawParams drawParams, System.Single pixelsPerPoint, System.Exception& immediateException) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
Rethrow as ImmediateModeException
UnityEngine.UIElements.UIR.RenderChain.Render () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIRRepaintUpdater.Update () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.VisualTreeUpdater.UpdateVisualTreePhase (UnityEngine.UIElements.VisualTreeUpdatePhase phase) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.Panel.UpdateForRepaint () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.Panel.Repaint (UnityEngine.Event e) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIElementsUtility.DoDispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIElementsUtility.UnityEngine.UIElements.IUIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& eventHandled) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIEventRegistration.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIEventRegistration+<>c.<.cctor>b__1_2 (System.Int32 i, System.IntPtr ptr) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& result) (at <9ff04fda545c4aacb8dab659ad40b2f4>:0)
https://drive.google.com/file/d/13xZbiG ... sp=sharing
ChrisHekman
Thanks for reporting this issue.
The error message seems unrelated to the cutout Shader.
Are you sure that this error only happens when you inspect the cutout Shader?
Return to “Unity”
