Unity Standard Cutout Shader is raising error
ArgumentOutOfRangeException: startIndex cannot be larger than length of string.
Parameter name: startIndex
System.String.Substring (System.Int32 startIndex, System.Int32 length) (at <695d1cc93cca45069c528c15c9fdd749>:0)
HelperScripts.Utility.ThousandSeparators (System.Single f, System.Int32 decimals, System.String separator) (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
OctaneUnity.RenderWindow.DrawStatusBar () (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
OctaneUnity.RenderWindow.OnGUI () (at <b50a8d4b3ee54fa58dc35de8c23ac9ed>:0)
UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect) (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEditor.DockArea.OldOnGUI () (at <9b8dec54b88e4aa9b9661a30f7e3f61e>:0)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.IMGUIContainer.DoIMGUIRepaint () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIR.RenderChainCommand.ExecuteNonDrawMesh (UnityEngine.UIElements.UIR.DrawParams drawParams, System.Single pixelsPerPoint, System.Exception& immediateException) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
Rethrow as ImmediateModeException
UnityEngine.UIElements.UIR.RenderChain.Render () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIRRepaintUpdater.Update () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.VisualTreeUpdater.UpdateVisualTreePhase (UnityEngine.UIElements.VisualTreeUpdatePhase phase) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.Panel.UpdateForRepaint () (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.Panel.Repaint (UnityEngine.Event e) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIElementsUtility.DoDispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIElementsUtility.UnityEngine.UIElements.IUIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& eventHandled) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIEventRegistration.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.UIElements.UIEventRegistration+<>c.<.cctor>b__1_2 (System.Int32 i, System.IntPtr ptr) (at <52d042b59b5f4b5fa4d9379442f5155a>:0)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& result) (at <9ff04fda545c4aacb8dab659ad40b2f4>:0)
https://drive.google.com/file/d/13xZbiG ... sp=sharing
Unity Standard Cutout Shader is not working
Moderator: ChrisHekman
- ChrisHekman
Thanks for reporting this issue.
The error message seems unrelated to the cutout Shader.
Are you sure that this error only happens when you inspect the cutout Shader?
