Crash report from Dominik; Houdini Version 19.0.383 [windows-x86_64-cl19.28]
Uptime 346 seconds
Sun Nov 21 21:43:16 2021
Caught signal 11
Traceback from 7312 ThreadId=0x00002848
CURRENT THREAD 10312
+0x7ffce64a2389 [Octane::ApiItem::pluginData] C:\Program Files\Octane\Octane_2021.1.0.4_Houdini_19.0.383_vr_Win64\bin\octane.dll
+0x7ffd007d1d0a [CMDextendLibrary] C:\Program Files\Octane\Octane_2021.1.0.4_Houdini_19.0.383_vr_Win64\dso\HoudiniOctane_19.0.383_vr.dll
+0x7ffd007fccec [HoudiniCompilerVersion] C:\Program Files\Octane\Octane_2021.1.0.4_Houdini_19.0.383_vr_Win64\dso\HoudiniOctane_19.0.383_vr.dll
+0x2943c904 [ROP_Node::nextExecute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29438600 [ROP_Node::execute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29443ece [ROP_RenderItem::render] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29447db7 [ROP_RenderManager::renderOrder] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x294476fa [ROP_RenderManager::render] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29432e12 [ROP_Node::renderCommand] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29432512 [ROP_Node::doRenderCommand] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x29431ef0 [ROP_Node::cmdRender] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x2bfafe8c [CMD_Manager::runCommand] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bf9b7f9 [CMD_Manager::internalExecute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bfae5e5 [CMD_Manager::processInput] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bfacd3e [CMD_Manager::internalSendInput] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bfb040d [CMD_Manager::sendInputNoLock] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bfaaf98 [CMD_Manager::executeNoLock] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2bfa65f5 [CMD_Loop::setupForStart] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x2eea70a1 [tbb::interface7::internal::task_arena_base::internal_execute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\tbb.dll
+0x62fa1185 [TBBPROXY_TaskArenaExecute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libTBBPROXY.dll
+0x2bfaae51 [CMD_Manager::execute] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libCMD.dll
+0x11142af2 [OPUI_RenderDialog::launch] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libOPUI.dll
+0x294381c3 [ROP_Node::doRenderCback] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libROP.dll
+0x269b97fd [OP_Node::triggerParmCallback] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libOP.dll
+0x1537201b [PSI2_DialogPRM::performParmCallback] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libPSI2.dll
+0x11003e8e [OPUI_DialogPRM2::performParmCallback] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libOPUI.dll
+0x1536bb86 [PSI2_Dialog::triggerParmCallback] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libPSI2.dll
+0x153683a3 [PSI2_Dialog::parmChanged] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libPSI2.dll
+0x15399892 [PSI2_Vector::changed] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libPSI2.dll
+0x11d66a3f [UI_Button::buttonTriggered] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x11e92334 [UI_TriggerButton::buttonTriggered] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x11d66bc6 [UI_Button::endSelect] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x1197aeae [SI_ParmButton::endSelect] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libSI.dll
+0x11eaf339 [UI_Window::handleEvent] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x11e4088f [UI_Queue::processNextEvent] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x11e3df49 [UI_Queue::drain] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x11e3e42d [UI_Queue::eventLoop] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libUI.dll
+0x119fe396 [AP_Interface::loadWindowGeometry] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libSI.dll
+0x119fed7b [myWinMain] C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\libSI.dll
+0x14000196e C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\hindie.exe
+0x14000222a C:\Program Files\Side Effects Software\Houdini 19.0.383\bin\hindie.exe
+0x7ffd56e57034 [BaseThreadInitThunk] C:\Windows\System32\KERNEL32.DLL
+0x7ffd57d42651 [RtlUserThreadStart] C:\Windows\SYSTEM32\ntdll.dll
Keep Getting Segmentation Error Crashes on Render
C. RAM Capacity (i.e. 6 GB)
- HandcraftedMedia
So in the scene I'm working with this seems to be happening every 10 frames or so. It looks like it crashes as it's saving. I tried running the render through PDG instead, and that seemed to be pretty stable, just a lot slower.
- HandcraftedMedia
I was rendering it in reload mode. Pretty sure I had the same issue in update mode though.
The scene is pretty good size, with a bunch of assets. What's the best way to pack it with all the external files included?
Please, double-check if you have the same problem in scene update mode. I ask because there is an old known issue while rendering sequences in full scene reload mode that I'm still investigating. If the scene is rendered fine in scene update mode, we are talking about this same issue for sure.
Anyway, you can send me any private information or scene download links by pm.
- HandcraftedMedia
Sure enough, when setting to update instead of full scene reload it does not crash... Sounds like the issue you are already aware of!
Hey, i keep getting segmentation errors also while rendering in full reload scene mode. Turning of multithread extraction and RTX acceleration seems to fix the problem. Although i'm not sure which one is causing the problem. Haven't tested it thoroughly. I just turned of both and it fixed the issue.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
I'll pm you the scene asap.juanjgon wrote:If someone can share any new scene with this problem I could also use it to try to resolve this issue once and for all.
