Noisy reflection from texture emmision
atoyuser1
Hi, I've found a few post on this subject, but not a straight forward solution.
I have this render at 1000 samples, but the reflection is still noisy:
1000 samples
1000 samples
Aside from adaptive sampling etc, is there something I'm missing? I tried upping the sampling rate on the emission texture, but that doesn't seem to help:
emission texture settings
atoyuser1
elsksa wrote:Hi there, proper sampling is primarily what should be correctly set, according to the scene. Light Sample Rate ≠ Light Samples.
This page does cover most of the important settings and could help: https://www.elsksa.me/scientia/cgi-offl ... r-settings
thanks for the link, I had a read through it but couldn't see anything directly linked to my problem, but I will have another look
whersmy
If you are on c4d and are able to export an .orbx, i can take a look at the kernel and settings :!:
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
atoyuser1
I cannot export orbx, but here's the C4D file. It's R24
test.c4d.zip
(82.54 KiB) Downloaded 117 times
test.c4d.zip
whersmy
I thought it was possible to export to .orbx with c4d. :)
https://www.youtube.com/watch?v=zzlPI68RRW0 here it`s explained!
atoyuser1
Ok I simplified it as much as possible, thanks!
test2.orbx
orbx
(64.86 KiB) Downloaded 132 times
render
render
atoyuser1
Thanks elsksa. You Obviously know your stuff. Looks like I have a lot of reading to do!
