Problem with Octane in C4D S24
samibetis
Hi! This is my first message in this forum since I started searching for new ways to improve my job in cinema4D.
My problem is that, when I start the Cinema4d and i assign de the folder where the Demo of octane is, Cinema doesnt recognize the plugin.
Is there anything Im doing wrong?
Thank you!
please, have a look at the following video tutorial on how to install the c4doctane plugin:
https://youtu.be/Dydb1JNfVFE
If you are using C4D R20/R21/S22/R23/S24/R25, you need to create the **plugins** folder inside the c4d directory, in lower case.
Please avoid to load the c4doctane folder from c4d menu Edit/Preferences/Plugins panel, or you will have a conflict:
Note that you always need to remove from the c4doctane folder, all the unnecessary c4doctane-RXX.cdl64/xdlib files not related with S24 specific versions, and leave only one c4doctane-S24.xdlib file in Program files/Maxon/C4D R24/plugins/c4doctane directory.
ciao,
Beppe
