Licensing and switching from one pc to another
spigolo
Hello
I always have problem to logg off from one pc (in my studio) and turn on my studio subscription at home (laptop)
Should I go to the Modo authenticate options and log off and than log off also from the octane stand alone,or is just
enough the Modo authenticate?
Many thanks
3dsign studio
Advanced visual communication
http://www.3dsign.it
Hi. You shouldn't need to logoff - simply shutdown Modo in your Studio prior to starting Modo on your home laptop. If this is not working, please open a ticket with OTOY via the Support menu option at the top of this page.
marchermitte
Well, I want to use modo to render an image using the Modo F8 renderer on one machine and the Octane for Lightwave plugin on another one. I can't. When Modo is started on pc # 1, the license is not available any more on machine n# 2.
When I try to log out on the Octane plugin on PC 1 (the Mdo plugin) , All I get is the autentificate button, with no option to log out. Meaning that, It looks like Octane isn't activated on Modo using the native renderer, but PC 2 claims that the license is already in Use.
SOmething else: when I insist, log out from the lightwave plugin to try and re-enable the plugin, I get a message stating that I need an internet connection to authentificate Octane (which I do)
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
3dcgmodeler
I am having the same issues...
getting the Active License on the web site, It's giving me the message need to close all instances of Octane
well i closed everything down, rebooted machine and still get the same message
Octane is still free right ???
was curious
ASUSTeK COMPUTER INC. ROG STRIX TRX40-E GAMING Rev 1.xx
1Ryzen Threadripper 3970X 32-Core - 3900 MHz (32 cores, 64 threads)
131072 MB DDR4 DIMM 2133 MHz (8 of 8 slots)
3dcgmodeler wrote:I am having the same issues...
was curious
Can you please open a ticket with OTOY about this via the Support menu option at the top of this paage.
3dcgmodeler
I did open a ticket
but they just do not have an answer, after 15 emails back and forth they have "NO" solution
Return to “Foundry Modo”
