About NetRender....
I have 1master & 4 slaves. (10G Network / Firewall Setting Ok / Same Studio Driver Version / Bind 4 Slave - Node Running)
1. Load Scene. LV NetRender is OK... LV ... LV....
2. Finished Scene Setting. after PV Net Rendering (Red Text : NetRender Gpu 8/8 Slaves:4 Data0:0Mb) -- Slave not running)
3. Shutdown C4D. reload Scene.
4. Right away PV Net Rendering. (Green Text : NetRender Gpu 8/8 Slaves:4 Data: 1377:3931Mb)
What is the problem. My scene has no any c4d shader.
Any Tips?
Can't PV NetRender....
- eyeonestudio
- Contact:
It is possible to generate a log from the daemon, and run it in a more verbose mode.
Please, copy paste the attached `octane_daemon_log.txt` file in the Render-Node directory:
octane_daemon_log_flags.txt.zip
Then please perform a couple of rendering sessions with Network rendering active, and the Render-Node connected.
Then navigate to `C:\Users\UserName\AppData\Local|temp`, or write %TEMP% in the Explore path field.
Locate the octane_damon_log.txt file and share it in your answer, thanks.
It would be nice to have also the corresponding c4doctanelog.txt file from the Workstation.
So before starting to render in Network, please, open a scene, connect to the Render-Node, then go to c4doctane Settings/Others tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View with Network rendering active, then in Picture Viewer, shutdown c4d, reopen, render in Picture Viewer, then navigate to c4doctane Settings/Other tab, press the **Generate log report** button, and share the octanelog_report.zip file, thanks.
ciao
Beppe
ciao
Beppe
