Camera visibility toggle broken on geometry lights
adamnerva
Hi. The camera visibility toggle on octane geometry lights, created via the octane panel, is broken and the lights always render directly in camera.
BK
adamnerva wrote:Hi. The camera visibility toggle on octane geometry lights, created via the octane panel, is broken and the lights always render directly in camera.
Hi adamnerva,
Thank you, we are unable to replicate this issue.
would you please share a sample file for us to investigate?
cheers
Kind Regards
bk3d
adamnerva
I can't always reproduce either, but I am attaching a scene with the problem. Maya 2022. Latest octane build.
Thanks.
octaneLightVisibilityBug.zip
(17.07 MiB) Downloaded 277 times
adamnerva
OK, I've figured out how to reproduce. Toggling the lights off and on a few times breaks the visibility settings. See attached.
-Adam
BK
-Adam
Hi Adam,
Thank you so much for the file.
Would you please disconnect the Emitter material{octaneDiffuseMaterial1) and use the parameter from Simplified emiter mat. setup rollout while we are debugging?
cheers
Kind Regards
bk3d
Return to “Autodesk Maya”
