I've used HDRI's for environments but plugging the texture into the texture environment and this works well.
However instead of doing that I'd like to map the image onto a polygon and the place this behind my subject. However I've noticed that the image loses all it's 16bit info. I've tried changing gamma and brightness etc but it looks like 16bit isn't supported in surfaces, whereas it is in the render target, is this correct?
Thanks, Alex
						HDRI Image loses 16bit info in surfaces
I'm not a lightwave user, but if I understand what you are trying to do, you can map your HDRI onto an Area Light and use that as your backdrop. Either that or use it as a luma map on a normal polygon. But I think there are some render optimizations in Octane that make actual Octane Light objects more efficient.
